quick question about running amp bridged
talon2nr7588
ok take a look at this amp http://www.sonicelectronix.com/item_5382.html# if you click on the photo of it it shows you more photos it has a two channel output. i got 2 15" L7s 2 ohm version and was wondering if it would be better to run them bridged at 2 ohms for 3200 rms of if i wire them a single channel for each. i can wire them parrale for a 1 ohm load per sub but if i do will it create a .5 ohm load since they are both connected to seperate channel or would each channel get a 1 ohm load?
do i have to wire the speakers together exacly the way it is in the sticky? or can i have they wired both in a series and have two wires going into the + and - on the bridged teminal. will it still be a 2 ohm load?
talon2nr7588
talon2nr7588
Indiana
knotslck
