Quick Question About Quantum Audio???
Do their amps put out rated power? My friends fixin to buy one and im telling him there is now way they will do rated power for so cheap? I may be wrong though, so im askin you guys on this. If im wrong so be it, but $279 for a 4000watt amp dont seem right? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Thanks for the help...
* 2000 RMS x 1 @ 1 OHM
* 4000 watts PEAK @ 1 ohm
* 1 ohm stable
* Top of the line Components
* Heat Management System
* Built in sub-sonic filter
* High Efficiency Mosfet Power Outputs
* Built in Low Pass CrossOver - adjustable at 12 dB per octave
* Bass Remote Control
* Illuminated Logo
* Class A/B
* frequency response: 20-28KHz
* THD: .05 %
* S/N Ratio: Greater than 95 dB
* Input voltage: 11 - 14.4 volts
* Adjustable Input sensitivity: .2 MV - 5V
* bass boost control @ 45 hz - 12 dB
* 1 ohm stable
* 1 x 4000 watts @ 1 ohm
* 1 x 2000 watts @ 2 ohms
* dimensions: 11.5"H X 19.68"D X 2"D
revrider1
Hmmm...
revrider1
Down South~3rd Coast~TX
revrider1
Mike Mccabe
