Quick question about hooking up a HU and Amp
D-DAY
17
La
I have a DEM-P7800MP and I am going to run a 2 chan amp to the front speakers. The HU has RCA outs for Front, Rear, and Sub. When I hook the RCA cables for the front speakers up to the amp, does the HU still push power thru the speaker wire running from the back of the HU to the speakers. (Just like a regular HU install w/o the amp???)
It really depends on the head unit itself. The only way to find out is to try it out. Hook up the front RCAs, and unplug the front wires coming from the head unit. If it powers the front speakers, great. I know mine is really shitty in the fact that you must either have ALL rcas or ALL wire. It won't do both at the same time, which pisses me off a bit. Good luck!
Well I was thinking that maybe I could use the unused HU wiring for the front speakers to power some tweeters. I just really wanted to know if the HU kills the power to the front speaker wires when you hook up the front RCA cables. It probably won't work, I was just trying to think outside the box.
i use rcas for my sub amp and for my front speaker amp and still use HU power for my rear fill soas far as i know using the rcas does not kill the hu's ability to run speakers.
so for instance i am running fronts on a seperate amp and i could add say a set of tweets run by my hu's front speaker power.
That's what I needed to know. Thanks.
D-DAY
D-DAY
La
EzekialPhoenix
vegang
vegang
