Quick question about gauges.
macq32
Hey guys, I have the following speakers set up:
Kappa 60.5cs (100rms)
Kappa 693.7 (110rms)
I was powering these with a Reference 475a amp and used a 4 gauge.
I blew my amp last month and am upgrading to a Fosgate Power 1000 25 to life 5 Channel amp (about 1400w)
I am also adding a 13tw5 to the D, so I am looking at putting about 900 watts through the amp. The amp suggests a 1/0 gauge. I am planning on adding a 2farad capacitor to the set up. I contacted a professional who suggested that as long is my gauge is a true 4 gauge, the 4 gauge should be plenty especially with the help of the capacitor. Agree or disagree?
Just trying to get a few more opinions on this!
I wouldnt get a capacitator because quite frankly their useless, get a deep cell battery...Since you already have 4 gauge setup in your car I would keep it, but it wouldnt be a bad idea getting 1/0 gauge incase you wanna upgrade later which u most likely will
Thanks for the opinions guys
ok so im going to look into the Big3 upgrade, which im pretty unfamiliar with... so I'll weigh that out with the capacitor/new battery and read up a bit.
So here are combination's that would work (some better than others)
Upgrade Cell Battery, keep 4awg - I have stock 90amp saab alternator, is this an issue?
Upgrade to Big3, keep 4awg
Add Capacitor, keep 4awg
Get rid of 4awg, add 1/0awg
Is this right? these would all "work"
Now its a matter of what is best?
Still need to get rid of cap. They don't work, just upgrade your battery and if you can add a second on as well. For the alt questio it is always a better idea to get a higher output alt.
How would a batcap400 suffice? I went in another local shop today and talked with a few of the guys who were a bit more helpful with providing a few more options (assuming the information is correct).
Initially they agreed a 4awg should be enough, but after looking at the draw of the amp (250a) they insisted 4awg would not cut it and that I should go with the 1/0. The only problem there is that 1/0 and 250a is likely too much for my stock electrical to handle, so we left it with this being my best option:
I am planning on upgrading the Big3
I would replace the 4awg with a 1/0
And finally I would add a Batcap 400
I'm under the impression this might be the best way to go without replacing my alternator (for now anyway).
Does this sound like a good option to anyone?
Thanks for the help guys, much appreciated.
macq32
macq32
Charleston, SC
macq32
