Quick question about disconnecting battery
Supergumby5000
Project: F350 begins...
Alrighty, i have two batteries in my truck. A kinetik under the hood, which is tied to a kinetik underneath the back seat, and the amps are all connected to that rear battery. I want to switch out one of my amps. Will it be safe to just disconnect the ground on the rear battery, or should i disconnect both batteries grounds?
The front battery is the main ground. You are correct about that. But since he is only changing connections on the rear battery that is the only one that he needs to disconnect, but it wouldnt hurt to disconnect both batteries.
I just take the fuse out by the back battery that connects it to the front battery. That way they arent connected. I probably should have stated that.
That would be a better idea so you don't have to mess with the ground on the front battery.
Supergumby5000
Supergumby5000
Pullman, WA
ultimate157
vegang
vegang
