Quick question about Daisy-chaining
Daisy chaining amplifiers means running an RCA pass-thru from one amp to another. It makes installations easier without the need for y-splitters when running multiple amps. This will not give you 5200watts @ 2ohms. Each amp will still be independent of one another.
Ok so in my case having the subs wired at 2 ohms, each sub will be seeing the rated power at that given ohm load which is 1700 w? if the subs are in the enclosure which only has 1 terminal how would I wire the POS and NEG to the chained amps? it doesnt have anything in the manual
I have the manual right here in front of me, it show how to wire a single D1 coil sub to the 2 amps should I do it like that?
Yes wire each sub in series, then take the 2 positives from both subs and wire them to one amp and the other 2 negitives from the 2 subs to the other amp.(parrellel)
Jackson00
Jackson00
Killa Kali
gunz4me
vegang
vegang
