quick fiberglass question
just use regular fiberglass epoxy resin. comes in pint and gallon, is just a regular liquid\syrup consistancy. the MEKP comes with it, it is the hardener, if you dont have enough MEKP [methyl ethyl keyotene peroxide if you wanted to know], you should be able to find some on the shelf where you are buying the resin at. MEKP is all the same, its just a chemical. it looks just like water.
usually looks like this
but you CAN get it in a paste - so DO NOT buy the paste lol. the paste is for bodyfillers and things that are a paste.
but your resin SHOULD already come with MEKP - so dont worry about it //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
alright thats whats up...cause i got some giftcard for autozone and advanced but i noticed that advanced only carrys the jelly resin......could i use that okay?
you still need bondo for it, unless you plan to put some hammerpants on it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif carpeting or covering it will still show the imperfections (big ones, at least)
listen.
jelly will not work for this. its a ****in jelly, how do you expect that to soak into your fiberglass? hell, try it if you really want to waste money - but it will be quite a pain in the ***, it will be like trying to get jello to soak into a t-shirt - and this jello does not melt when it gets warm.
sorry req i just didnt know, i just needed my autozone card to pay for half the money for my clutch....maybe they'll have regular resin at advanced...ill check though
Jdizzle
tha dirty dizzle ;)
Jdizzle
Carthage, NC
cxixer
