Quick Easy Question for anyone
mrbomb
Bringing the BOOM
I am getting two 10's and the recommendations for one is:
sealed enclosure size: .6 cu. ft
ported size: 1.4 cu. ft
port size: 3" dia. x 8 in
so im just going to double check that when having two of these subs all you need to do is double the dimensions
also would everything be the same if the port is outside of the box? i could draw a picture if thats a little confusion
simple answer =yes
so if it calls for 1.4 cu ported for each sub you would build the box to be 2.8 plus whatever the sub displaces. port outside the box (i'm assuming aeros or pvc) will be the same except that the length will change by the thickness of the wood if attaching port to the outside surface of the box.
mrbomb
Bringing the BOOM
mrbomb
south west michigan
mrbomb
