Lowjacker
1/1 of SexualConstipation
Was readin' another thread and came across the information that multiplying the fuse rating(s) by voltage will give you the wattage of the amp.....
Is this true?......at 4 Ohm?......2 Ohm?.......1 Ohm?.....
If 2 fuses are present is it one per channel or are the ratings added together and then multiplied by the applied voltage?
Why I'm asking is that my 150.2 amp has 2 30amp fuses and is getting about 13.6volts.....so is it really closer to 600 watts?
How exactly is it figured up?
