.::DuD3::.
EE in training
do yall ever run 2 subs from a mono channel amp? just wondering, never done it personally, but i see people do it all the time.
i just usually looked at 2 channel amps to run 2 subs, but i take it you'd just divide the rms by 2 correct? since 2 subs would be running off that one channel.As long as the impedance works out, why wouldn't you?
correct. don't know if it would be exactly by two. like 700 on two subs might not be a full 350 each but i could be wrong. it would be close though //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifi just usually looked at 2 channel amps to run 2 subs, but i take it you'd just divide the rms by 2 correct? since 2 subs would be running off that one channel.
there's a rockford fosgate picture floating around somewhere that has a bunch of different ways to wire subs....i'll see if i can find it i couldn't find it when i needed it last timenow is there a fancy way of wiring the two subs together? or do you just twist the sires together to get a final positive and negative. i just dont wanna blow anything up lol.
