quick amp question
do you have subs. If so whats the xover set at that amp. At any rate if you have subs leave it at high and just adjust htings on the headunit to get them sounding nice. If you do not have subs then you may want to change it to full so you can have a little better sound system than just all mids and highs
if u have subs..then u switcht the crossover to LOW PASS! and crossovers are usually like 30 to 250hz. you dont set to HIGH when u have subs. u would ruin ur subs cuz it lets all the highs through and which the subs coudltn produce them so it ruins em
Originally posted by kottonmouth if u have subs..then u switcht the crossover to LOW PASS! and crossovers are usually like 30 to 250hz. you dont set to HIGH when u have subs. u would ruin ur subs cuz it lets all the highs through and which the subs coudltn produce them so it ruins em
He said speaker amp there buddy. Calm down:) I said if he has subs he should turn his speaker amp to high pass.
ziggy_2k
ziggy_2k
La Jolla, CA
mr4pto
