question
whats the reason for bad advice?
start ur car measure at the battery terminal should be atleast 13.8volts can be as low as 13.2 if you have a bad battery.
if its lower that 13.2v your alt is bad and should be replaced asap because you might not have ruined the battery yet...
With my truck running I get 14 volts, at the amp still around 8-9 volts, now I'm confused, could it be because I had to shave off some of the 0/1 gauge wire to fit it in the amp power/ground terminals?
check ur amps ground is clean and tightcheck ur battery terminals
test with a dmm pos on amps pos and dmm ground on trunk or hatch latch...
This, you can also check our ground by checking your ground and remote with a dmm. This will also tel you if you the issue is in the ground or power wires/connections.
mr.gaf
mr.gaf
Shreveport, LA
mr.gaf
