Question wiring in 2 10" subs.. one SVC one DVC
i got this setup and it was in a different box, andi guess one of the coils on the DVC wasnt even hooked up.. so when putting it into the smaller (unported) box, i saw how it was wired and scratched my head as well... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
What's the impedance on each sub?
4 ohm for both.
memphis MC-104
RMS Power Handling: 200 watts
Peak Power Handling: 400 watts
Double roll polyprene surround: Better control over cone movement
Ribbed polypropylene graphite cone
Dual flat spiders with graduated rolls
Single 4-ohm voice coil
4-layer winding on 2" Kapton® former
Vented basket and vented spider spacer
Aluminum heatsink
Sensitivity: 86 dB
Magnet Size: 50 oz.
Memphis MC-104D
Dual 4-ohm voice coil
Aluminum heatsink
Sensitivity: 86 dB
Magnet Size: 50 oz.
Mounting Depth: 5
they will play together but which ever has the lowest resistance will get more power than the other...depending on amp......upto 100% more...now if you have a quality amp that will run mono and stereo you can wire the DVC at two ohms and the SVC mono and they will see the same power such as a good old school AB amp that is one ohm stable...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
AB amp/ More info? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
camaroguy72
camaroguy72
CT
camaroguy72
