Hence why I said keep the gains down (nothing wrong with a little head room).bramahs and xxx handle the same amount of power 1600, xxx's dont need a 1400 rms and cannt handle 2000(you would ruin the sub really quick like this), 700-1000 is enough to drive it to full excursion and deping on the box you have , just because its rated at 1600 rms dosent mean its a requirent thats a THERMAL rating, and brahmas can take a minimal of 600rmsfor its full potential if they got the biggest box.
and to answer youre question 2 12's at 1000 would defienently have more output than 1 15 with 2000rms theres a LOT more cone area, as a matter a fact you would ruin youre 15 with that much power over time.
with that much power you WILL need a high output alternator , and the formula is the toal rms power, times 2, divided by 13.8, and that equals the current draw, if youre a little but over youre alternators output youre fine youre just gona pull from you battery, if youre a lot over youre gona pull a lot from youre battery and it might be a problem, in youre case youre gona pull a whole ton , so yeah do a alternator, check out mralternator.com .I'll probably hook my other amp for the components up to the OEM battery. And put a second one in the trunk somewhere. Do I need a new Alternator as well?
you sure as hell do , i got a single 12 xxx and in ONLY giving 550rms(temporary, just picked up a kicker kx 800.2 for 143!)and it is very impresive.Also you would be surprised in how much a 15 in an adequate install can sound. One 15 in a ported box can really get the job done. Also you get to suprise people with single woofer setup.
people keep telling me that a xxx is ment to go ported(not sure why)so for a 12 you would need 2.5 cubic feet "slot ported" suggested by the site, on 15's not sure got to check, but yeah do ported.So should I go with ported? Cuft? I think it's called? I don't want sealed with only 1000 watts correct?
The person who is selling the Tarantula amp has a feedback rating of 0. I wouldn't trust that much money to someone who is new to ebay.I'm finding the Tarantula D class 2000 watt amp on ebay for like $865. Should I be skeptical about this price since it retails for over $2000? Would paypal help protect me?
Also, component amp do you think an VGA320.4 would suffice 80x4 @ 4ohm or should I go with the VGA500.4 125x4 or would that be a little too much for my speakers. Ebay is selling the 320 for $199 and the 500 for $289!!!!!
