question on wiring a sub
just like this //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
EDIT-
Does the 600.1 have the dual output terminals like the 1200.1 does ? If so you could just connect the positives from both coils to the positives on the amp, and both negatives to the negatives on the amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this is a picture of the amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks
qball
Okay it's the same as the 1200.1. You can wire either way I showed ya above. Both ways accomplish the same thing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks.
now i just have to wait on my sub getting here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
qball
i wired the 2 postives to the postive terminal and the same for the neg.
so im assuming its down to 2 ohms now?
what if i bridge it too? would that make it go down to 1 ohm or would it stay at 2?
tnx
Qball
Originally posted by Qball i wired the 2 postives to the postive terminal and the same for the neg.
tnx
Qball
Yes sir that would be paralell wiring. And yes it is showing the amp a 2ohm nominal load. And you can't bridge a mono amplifier. It's only one channel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks ramos //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif *bangs head on the wall*
Qball
Qball
Qball
Everywhere
ramos
