Question on Preamp outs..
F150Truck'in
On my Eclipse XA4000, I have Front Left and Right inputs, Rear Left and Right inputs, Preamp out Left and Right...
what signal is passed to the Preamp outs, Front or Rear or combo of both Front and Rear, I have the manual, but it does not say what souce signal it passing to the preout...
Any body know....
On my Eclipse XA4000' date=' I have Front Left and Right inputs, Rear Left and Right inputs, Preamp out Left and Right...
Any body know....[/quote']
If there isn't any crossover control for pre-outs, then 99% sure it's just pass-through from input, most probably not even electrically isolated. Front or rear - ??? Only experiment can show //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://www.eclipse-web.com/amp/ice.html
Adaptable four channel amplifier that can be bridged to configure a more powerful two channel unit that provides 350W per channel. Subsonic filter and variable bass boost are provided as well as high and low pass filters.
ICEpower full-range Class D operation.
Attractive design for practicality and ease of use with all controls such as level, crossover, low frequency boost and high/low pass filter adjustments mounted on the top panel.
Output terminals conveniently located to allow multiple in-line unit installations.
Bright LED indicators also mounted on the top assist in setting system levels to prevent amplifier clipping.
Very high efficiency rate with low current draw.
http://www.eclipse-web.com/amp/xa4000.html
Those outputs just pass the signal to second amp, if you have one.
No crossover, just straight through.
F150Truck'in
F150Truck'in
Chesterfield, Va.
Rich B
