question on how does induced noise sound like?
  • Thread starter virux
  • Replies 0
  • Views 481
virux
I don't know if I am getting induced noise or not. When I turn the level signal of my 4 channel amps too high.. I'd hear this constant noise coming from my speakers. My amps are always on, so I turned off my HU and I'd hear this sound like its a tv with no signal. But I could lower the knob to a lower level to the point which it will disappear. Im not sure if turning the signal level too high will cause this but my speakers are 50 watts rms and my 4 channel amp is 50 watts rms per channel. So I'm thinking it should be able to turn my signal level knob high to a point which will still give clarity to the speakers when volume is turned to 2/3.
I'm using a line level converter which has 4 individual level controllers from 2-60 watts per channel for rca outputs (called PAC OEM-2).
If anyone could provide any kind of help in eliminating this "noise" problem it will be great!!
thanks
virux
virux
New York
virux
