Question on big 3 engine ground
Bigrick31
Carpe Diem
Well im about to put my truck on air bags next month and i will have to do some relocating of a few things under the hood so i can layout on 22s. well im going to relocate my battery to the bed of my truck. this brings up the question. i can run the alternator wire to the bed and ground the battery to the fram of the truck in the back. however there is a ground to engine block what should be done about this? it would be such a long run from the engine bay to the back of the truck especially for a ground. what should be done? ground it to the engine anyways or just forget about it? or ground it twice to the frame?
A ground is a ground, as long as it is hooked up to a good place on your chassis, then you should be good to go. Have fun with the bags, always wanted to do that...//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
thanks ( i just wasnt sure if the engine needed to be specifically connected to the neg of the battery for some reason) ill make sure to post tons of pics when i bag my truck. i cant wate to do it!
Thats right as long as the engine is connected to the battery in some way like
battery to chassis
chassis to engine that way it is a loop and everything is connected back because it all flows through one another.
Bigrick31
Carpe Diem
Bigrick31
Mid*Cal
Perdonic
vegang
vegang
