Question for you guys...
dmbrichie
So I got all my stuff now
2-Jl 13tw5 -3 ohm subs
1-Rockford Power 600x2
2-sets of Rockford Power 6.5 component systems
I know I kinda screwed up with buying this amp seeing as how it won't go to a 1 ohm load, but I have it and I was hoping to use it obviously... I talked to the guys at my local car audio shop and they said it was possible to run my amp at a 6 ohm load to run the 2 3 ohm subs... I was gonna run the subs in series to gain this 6 ohm load... However looking at my amp specs it doesn't even show the amp rated for a 6 ohm load, any ideas guys??? Please let me know asap, thanks alot...
200W x 2 @ 4-Ohms RMS
300W x 2 @ 2-Ohms RMS
600W x 1 @ 4-Ohms bridged RMS
1-Ohm x 2 Stable
2-Ohm x 1 bridged Stable
you could try and run it in parallel bridged and see how it works but it will be around 1.5 ohms a little lower than specs or just play it safe and run one sub on each channel
dmbrichie
dmbrichie
Rochester, MN
DammitJames
BP1Fanatic
BP1Fanatic
