Question for sq
Buck
little alien on campus
How would I do t/a and tune all of my speakers if I had more than 6? What device would I use? In my case, I was thinking of running set of tweets off of 2 channels, and a set of mids off of two channels, and then have a sub. But if I wanted to have rear fill or something, all my channels would be used. Now I wouldn't be able to tune or do t/a because. So how would I add more now that every channel is used, and still be able to do the "SQ" things?
you running active i assume? and your h/u has 6 channels?
Yes running active. Alpine 9887. Front/rear/sub or high/mid/low. Just depends on which setting it's on.
run one W7 and it will correct all your time misaligned problems
//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
nice to know
Usually people just run 3way off their HU and daisy chain out to their sub amp. Flip the phase on the subs and it might help bring the substage up front. That's what I'm having to do right now.
If you must, what I would do is run y's from the rear outputs. Which I would imagine you would have bandpassed if you did it right. Then run a second amp for your rear speakers and put the second amp on a toggle switch so they can be turned off //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well I'm not active yet, because I had shoulder surgery and haven't been able to change up my speakers. But I can bandpass them at the amp.
Buck
Buck
Inside of a pyramid
Buck
