- Thread Starter
- #16
[quote name='quackhead']Yes, they are in fact mono sub outs, in which case, it appears to be wired correct. this is good, since your subs share the same airspace.
from pg 23 of this: http://www.docs.sony.com/release/CDXGT700HD_EN_ES.pdf
Audio outputs terminal (front/rear)
Subwoofer output terminal (mono)
Power antenna (aerial) relay control terminal
Power amplifier control terminal[/QUOTE]
@quackhead Are having mono-subs outputs and advantage or a disadvantage. When I get a proper mono-block amp how will play be affected since mono-amps have separate channels? I read that mono-block amps have 2 amps built inside, one for each subwoofer. Is that correct, perhaps I am not remembering details verbatim. And thanks for the amp recommendation, really helps to have some options, though I doubt I could really go wrong with the Kenwood.
