Question about using RE XXX 2ohm passive crossovers with 4ohm mids and tweets
The problem with this idea is that the impedance of the tweeter on a comp set is usually not the same as the nominal impedance of the set. IOW I doubt very much the tweets are actually 2 ohms. You really can't predict the crossover freq.
Thank you guys for the responce. I'll give them a try at low power to see how it sounds. This is just a temp. fix till my 8ch amp comes back from being repaired by ZED audio. Thanks again.
SomeguyinPDX
GunHappy
SomeguyinPDX
Portland, Or
SomeguyinPDX
