Question about spiders?
ok,
if your looking at the spider, if its "bumps" are all the same size and length then thats a linear spider. if the "bumps" start out larger and get smaller, that a progressive.
as for the differences, i think that in general progressive spiders offer a tad more x-max capability and mabie a lower fs. the other type may offer more controll and power capability overall but this is just a guess.
The main purpose of the spider is to provide a restoring force to the speaker, returning the coil to the rest position where it is centered nicely beside the top plate and within the gap.
When the coil moves, the spider is stretched. The further the spider is stretched, the more it resists moving further. This is an increase in stiffness (the same as a decrease in compliance), which can result in a loss of output and/or increased distortion.
A progressive roll spider is designed to keep the stiffness of the suspension as constant as it can throughout the coil's motion. The further the coil moves, the more useful it is, so they are more common in longer-throw subwoofers (since that sort of excursion is required for high output at low frequencies). It is still useful, though, in virtually any speaker that seeks more "clean" throw than other speakers of a similar size. You must still be careful, however, to avoid using a spider that would easily allow the driver to encounter mechanical damage from over-excursion; in particular, it is useful to make the spider significantly stiffer at the outer edges of the coils travel to prevent the coil and former from hitting the backplate.
I have heard, however I am not sure, that progressive spiders can suffer from sag over time since the outer area of the spider is a lot more compliant than the inner area. Like I said, I do not know if this is true or not so I am posting to see if you do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
First I need to clarify that post:
Do you mean that the outer area of a progressive spider is more compliant than the same area on a linear spider?
Or that the outer area of a progressive spider is more compliant than the inner area of that same spider, and this difference results in a progressive spider having more sag than a linear spider?
Pubic_Hair.ashx
From what I have read the inner part of a progressive spider is stiffer than a traditional linear spider while the outer rolls are more compliant than a linear spider. Again, I may be 100% wrong, that is why I am asking if it is true or not.
Anonymous
Anonymous
Cantonment, FL
bose301s
