Intercooler
Fronts and rears. Def Tech said the fronts should be 2x the distance from the viewing area to the flat panel. That would be about 24' which I don't have to work with. I have my sectional in one corner and could possibly put the rears behind it on stands but that would be cutting out the left side by like 6' or more. If I go out to the wall and put that one there it would use the whole room. The way my front wall is I have stairs going down on the right and up on the left. I can only get about 6' on the front wall for distance if I mount them to the extreme edge near the flat. The other option is to jump across the stair openings and put them to that wall which would give me perfect cornering on the left but the right side would be a little wider than a perfect square since that wall sits back about 6" more on the right side. Any thoughts?
