Question about pre-amp outputs
jasonli18t
I have a JVC double din headunit that has 6 pre-amp outputs... front pair, rear pair, and subwoofer pair.
The left front pre-amp output is toast. I would really rather not attempt to get warranty coverage for this because I don't want to take my car apart. So my question is, are the rear pre amp outputs the same exact signal as the fronts? Meaning if I simply swap to the rear outputs, will it sound the same? I can't see any reason why it wouldn't but I want to be sure they are the same.
Thanks in advance.
right shouldn't affect signal should affect fade
---------- Post added at 10:45 AM ---------- Previous post was at 10:45 AM ----------
signal would be affected if you had to use both left or right channels, front/rear are interchangable.
jasonli18t
jasonli18t
Long Island
jasonli18t
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
