Question about my Eclipse 8454...
Hayabusa
Audiophile
How do I adjust my Sub output so i can turn my sub up and down/off. What is SVC that I see when i scroll through SVC,Bass,Treble,Volume in Pro Mode? Also which RCA should by Sub be plugged into because there are like 6 sets on this thing hehe...
There is no "correct" setting....think of it as a secondary gain control. It is basically just to get all of your sources on the same volume level (or different if thats what you prefer). Think of it like when you change the channel on your tv and some channels are alot louder than others.
In Pro-Mode you will not have the ability to control the subwoofer's volume. This was the thing that bothered me about my CD8454 and CD8455. What I did to get around this was to have different EQ settings with different levels for the sub channel. You can do this by going to the time alignment menu and dropping some db's for one setting and then some more for another setting and saving these into an eq preset. This way you can adjust by just changing EQ settings.
The CD7000 allows you to do this now, but only in the 4speaker+sub mode, not in the 3way mode.....
Non-Fader option does indeed adjust the sub output //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif... Good stuff there.
Hayabusa
Audiophile
Hayabusa
Mississippi
Hayabusa
Mike Mccabe
