Hello,
In my trunk I have 2 JL Audio 12w3's being powered by a JL Audio 500/1 amplifier. I'm new to car audio so this question may sound stupid. I had the equipment professionally installed so I don't know much about the settings on the amp.
My question is, when the amp is powered, does it automatically use all of the 500 watts on the subs? Both 12w3's are rated for 300 watts, and as my amp is 500 watts, that means maximum wattage output would be 250 watts for each sub. When the amp is hooked up with the sub, is this power divided automatically? Or does this maximum wattage need to be tuned on the amp to get that power?
Since I don't know my way around amps, I just wanted to know if I am actually pushing 250 to each sub or if it's possibly less. And if it's less, do I have the ability to increase it to get the most power out of the subs? I guess my question is does the amp do most of the work for me, and I shouldn't worry, or does it have to be specifically tuned to get the max wattage to the subs?
The subs hit very hard, I was just curious about this. And wasn't sure if it makes a difference that the JL Audio amps are rated for continuous RMS and therefore stay at 500 watts from 1.5 to 4 ohms
Thanks
Thanks
