question about installing 0 gauge
one more dumb question: should the battery be disconnected when you wire a amp or should the battery be hooked up an then plug the amp in
I'd recommend 12-18" as if you have a meltdown issue not related to that wire, you can unplug the fuse without your hands being right on top of the battery. 6" is dangerously close if you have a direct short elsewhere in the car and are smoking the batt.
Always put the fuse holder in first, and leave the fuse out when hooking up the amp. Once everything is wired, insert the fuse. Leaving the power to the amp hot when you are installing leaves room for a slip to blow up amps/speakers and melt parts of the car. Bad idea.
416
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
763
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
499
MOFOMAN
MOFOMAN
Michigan
MOFOMAN
Brendon Jenness
    May 8, 2024
    May 8, 2024
