Question about input voltage
Your system charges at 14.4v if it is normal.
I looked, and Amazon is the only site I saw that mentioned 18v input voltage. I'm assuming that it just means it can be run on a 16v electrical system. 16v charges around 18v.
Specs should have been taken at 12v or 14.4v. I forget what PG rates their equipment at.
I know their old school stuff was under-rated. Great SQ gear
you are both assuming "input voltage" is DC battery input and not AC signal input. 18VAC is a common high-level input voltage rating. i assume that is what they are referring to - that the amp has high level inputs (specs say "differential inputs" which commonly accept up to 18VAC).
adjust the gain and put on low level input and you can get rated power out.
AstrixNix
AstrixNix
Pearl, MS
n2audio
