question about Fuse/power wire
No, but it is too large to be useful. Fuses blow to prevent overheating of the power wire from too much amperage. Using a 200 amp fuse on a wire that can't handle 150 amps means that when the wire gets a 175 amp surge, the wire will overheat possible catching fire because the fuse didn't blow.
wait, I know I'm thread jacking but...
my friend got a Kicker amp install kit and it comes with a 300 amp fuse....
we are using 1/0 awg but only for about 1000-1100 rms watts (hifonics 1606D @ 2 ohms)
fuse useless??
fuse useless??
Umm, no. A fuse is never useless.
Get a smaller one. 150a will do the trick.
Please explain why a smaller fuse is a bad idea. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you don't know, use the search button! //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I think he has a FS thread selling 300A fuses //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
What? 150A fuse for a 1/0 wire?
Needs to be MINIMUM 300A fuse...
No. This is a common misconception. If you understood current flow, the amount of amps 1/0 wire carries, etc, you would realize that a 300A fuse is too big for 1/0 wire. Sure, I know you've read it here a million times, but like I said, it is a common misconception. Instead of believing everything you read on forums, have you ever considered reading a book on electrical? Like JimJ said, explain how a smaller fuse is a bad idea.
As I said in an earlier post, perhaps people should not be installing equipment if they do not know how it works.
For you to say it needs to be a minimum of 300A proves to me that you are very unfamiliar with the way a fuse is designed to work.
kingisback08
kingisback08
buttfudging,nowhere
vandiar2
vegang
vegang
