I am trying to figure out how you know when to use seperate chambers inside a box for the different drivers....
You have to analyze the scenario in detail to determine what is best for a particular design.
For instance, you install a woofer, midrange and tweeter in a common
chamber. When the woofer moves it will push the midrange driver cone
and if you have a vented tweeter it too will move. Not sweet so you create
isolation chambers.
What if your tweeter and midrange driver are sealed ? Then it won't matter.
What if there is an air leak in the tweeter and midrange install? Then you have
another problem to deal with.
What if you have planar tweeter that is sealed but later you notice the diaphram
moves when the woofer moves, confused you analyze the tweeter and found
a build quality problem where the gasket used to create a seal on the tweeter
is not working right. Another problem to deal with.
What if you need the air place for the woofer and can't chamber the design?
Then you have a compromised design unless you solve the other issues.
What if you want two woofers in a box, do you chamber the design or not?
If one woofer fails, the sound is different. If the design was chamber the individual woofer is still performing to spec as it doesn't see the other woofer
in it's own chamber.
What if you can't make a multi-woofer chamber because the port size requirement is too big and won't fit? Then don't make a chamber design //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What if you make a tall line array with midwoofers sealed? Do you chamber or
do a single box ? midrange frequencies are the nasty ones that have standing
wave issues. A midrange in a small box will have nasty reflections on walls,
if you were to make a non chamber design and fully stuff the box with polyfill,
this gives the sound waves a chance to disperse and 'get lost' in the thick
polyfil to offer less coloration to the sound. On the other hand, by not have
a chambered design here, you have not extra cabinet bracing for a such a large
tower so you have to solve that issue another way.
The general rule is..> DWYW DIY
Do What you Want Do It Yourself
If you make product to sell, then do esoteric things to justify the higher cost
in spite that it may do nothing at all ... ie, we sprayed popcorn material on
the internal walls conforming to Fibonacci patterns to break up standing waves ->
cha-ching -> product sells for 2x more. //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif
