Question about calculating crossover slope
he wants to know at what point the LF is actually removed from the signal reaching the speaker.
I'm doing it assuming crossovers roll off at a linear slope, which they don't, but I think it's a reasonable approximation. Someone who knows how to apply logs will have a more accurate calculation, but the way I figured it...
If you have a 24db/oct crossover set at an F3 of 50hz at a base power of (for simplicity) 100w
the speaker should see half the power at every 3-1/8hz.
The 0dB level would be 53.125, f3 or -3dB (50w) @ 50hz, f6 or -6dB (25w) @ 46.88, f9 (12.5w) @ 43.75hz, f12 (6.25w) @ 40.6 etc.
Hopefully that's in the ballpark. I think that's off by a step from my CS reply Quick.
i didnt check your math and im sure its fine, this is just to the op..
dont forget where the crossover point is.. its -3db's
n2audio: Good info Thx!
So...can I just double those figures if my amp does 200W per channel?
quick01
quick01
Woodstock Ga
n2audio
