Question about bypass relay...need help asap
08Accord
When i hookup the relay to bypass the parking brake, if i have an aftermarket amplifier, do I run the remote wire to the amp from the relay itself (the terminal the remote wire is connected to), or do I run it from the remote wire before the relay? I have a Pioneer AVH 3300BT. Thanks you guys.
It doesn't really matter as long as you're not running the remote wire to the amps off one of the other relay terminals (one that actually turns on/off with the relay).
I have an AVH4200 and just crimped two wires off the remote wire on the headunit. One runs to my amps and the other runs to the bypass relay.
//content.invisioncic.com/y282845/emoticons/iagree.gif.15d6c075ee8d3913ba26866d06993068.gif, its easier to run it from the relay terminal as well. I would just twist the remote wire and the amp remote wire together and crimp a spade connector onto them and then connect it to the relay terminal
08Accord
08Accord
boca raton, fl
All_Logix
