Question about backup power options for security cam
Hey -
I bought and installed a Boyo VTR-300 Black Box recorder , and 2 cameras (front and back). I have the system setup to record all the time, rather than just when the vehicle is on. So that it doesn't run down the battery, I've installed a "Wiring harness" from GPSskytracker . com ; I have no idea how it works but what it does is cuts the power to the system after the vehicle battery drops below 12V.
Everything works well and as expected. However, currently the battery only lasts 3-4 hours after a drive before reaching the 12V point that kills power to the system. I was wondering if there's a way to extend the power to closer to 12 hours of life.
Preferences:
-Lightweight (not just adding another full-sized car batt)
-Relatively easy to install
-Self sustaining (i.e. recharges on its own so I don't need to separately charge)
Any thoughts or ideas?
Here is the power usage info:
-Front Cam: "Power Source DC12V, Operating current 90mA w/regulated 12VDC in"
-Rear Cam: "Power Source DC12V (tolerance: 7V-28V), Operating current 90mA w/regulated power in"
-Recorder: "Power consumption: With 12V; 570mA, with 24V; 285mA"
why do you need to record all of the time? why not set to trigger upon an event (movement or sensor)?
start by replacing your battery. you have less than 800mA of draw, which will certainly drain a battery, but it should be able to last for several days before dropping below 12V. it's all about the reserve capacity of the battery.
i recommend a good AGM battery as you main/starting battery. get the highest Reserve Capacity you can fit in the stock location.
from there, i fully support the idea of a few small solar panels. a 5W panel would almost cover your needs, but 10W would be perfect.
Thanks guys. Unfortunately solar panels or trickle chargers aren't an option; I park outside with a cover most of the time. My current battery is an Odyssey PC925, with a 52 min reserve capacity. That doesn't seem low on the range available from batteries, especially considering keep_hope_alive's estimate of several days. Am I missing something? You can see the other specs of this battery here.
If I need to swap batteries, any recommendations for one with a much higher RC without adding weight (I'm already at 25lb and weight is important in my vehicle).
Thanks,
Colin
Aisle2
Aisle2
San Francisco, California, United States
Aisle2
