question about alternators.
I believe the rule of thumb is one amp for 10 watts, plus 36 for ECU controls, and 10 for extras (lights, etc.). So, if your amp averages 950 watts, your money.
nah...that really doesnt work.
the really only accurate way to tell is to get a clap meter and measure the current draw of your amp, and see what it does.
but im my opinon I think you will be fine, with that alternator.
Hmm, sorry then, I thought that was considered OK.
I suppose when I do it, I look at the alternators idle output, as opposed to it's max rating. I've never had problems that way, but it's possible thats a coinci...coinced...I got lucky.
Your formula is kinda... weird.
different cars draw more current than others. You can't just use "a rule of thumb".
A=W/V
1200w/13v(safe number)=92a max draw
alts have ~40% reserve
140(peak)*.40=56a reserve peak
idle is more like 70a sooo...
70(idle)*.40=28a @ idle
You may have dimming at idle if you listen to test tones all day. While driving you may also see dimming if you listen to tones. If you dont listen to tones you could simply install it and find out if you have dimming. If you do, upgrade your wiring then maybe get a better suited alternator.
i have a 275a peak(2.5k) and 140a idle my lights still dimmed w/ big 3 in 4/0, and a yellow top running 1 pbx 3000d....
That's true, I hadn't thought that through very well. 36 amps is what my old truck drew.
Well, thats why I come here...to get all the facts straight!
Thanks guys.
Intensity
Intensity
Hollywood
PyroBob
