Quarter round for internal corners?
Apart from changing box volume modifying the shape of those corners shouldn't make any difference at all. Throw it in there if you like, it should provide extra strength for those joints if nothing else.
OK I understand that. I did caution anot her piece for a double baffle for added strength. I was wondering if I could move the sub location. Dd plans call for sub front and poet the the side. Move the sub to top and port to side.
More importantly is which direction things face in the car which can make a dramatic difference in output and response, but you simply won't know which is best until you test in your vehicle. Wherever you put the port make sure it's not crowded into a wall and you should be pretty happy.
In the car the port with face the side and sub will fire in out out to the trunk. If I could have sub firing up that would be better so sub won get damaged.
sharkman
poor bass head
sharkman
oakland ca
hispls
vegang
vegang
