Pyramid PB1500
bjmoreton
Do you think this amp( http://www.amazon.com/gp/product/B000CHRJUA/ref=olp_product_details/102-3331424-5076112?ie=UTF8&me=&seller= ) would push a single kicker CVR 12" bridged(at 8ohms hopefully getting 750watts rms?) and eventually two kickers once Ig et the money for the other one? If not, could you show me an amp that would push one fine and then another fine once I got it for aorund the same price and the site has to accept bill me later... =\ Thanks
if you need bill me later for 75$, dont do it
No what? it won't push the sub(s) or what, lol? Anyways, I need bill me later because I do not own a credit card nor a paypal account mom won't let me use her credit cards just her bill me later account so... heh.
Also their the 4ohm one.
ok, I'm guessing you have a dual 4ohm kicker cvr. You can wire that for 2 ohm or 8ohm see this website: http://rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
Running said speaker at 8 ohm would be far to expensive. There is no sacrafice to quality by running it at 2ohm. If you were to buy an additional 4ohm d2 woofer then you would be able to run it @ 1ohm. The speaker is rated for 400wrms/800w peak. therfore if you were to have 2 running you would need 800wrms @ 1ohm.
the cheapest class D amp I have yet to find with decent quality is a BAMF power acoustik 2000d found here http://www.millionbuy.com/pakbamf20001d.html
it will do 1200wrms @ 1ohm (their spec sheet is incorrect check the official website)
that would give enough power for both of your speakers with low distortion (be sure to set your gains properly or risk blowing your speakers) It is also 1ohm stable.
So this would do fine with just one wired to 2ohms and then another Kicker CVR added later wired down to 1ohm?
I know I mean't since I have just one Kicker CVR right now I would wire it down to 2ohms for it, or 8ohms since one dual 4ohm sub can be wired to 2 or 8 ohms. Then LATER I would add another dual 4ohm sub(which would make two dual 4ohm subs) and rewire them to 1ohm correct?
bjmoreton
bjmoreton
Sabina, OH
bjmoreton
