pyramid 2000 watt:enough power?
that amp does 75 watts peak x 4 @ 4ohms so bridged to 2 channels if your lucky you might get 80 watts rms per channel I have no idea where they get 2000 watts from on that amp.
Product Description:
Pyrmaid "Artic Series" 4-Channel Amplifier 2000 Watts Max
Details:
·Four Channel Bridgeable Amplification ·Tri-way Configuration: 4/3/2 Channels ·4 x 75 Watts Total Output @ 4 Ohms ·2000 Watts Total System Output @ 4 Ohms ·Variable Gain Control ·MOSFET Pulse Width Modulated Power Supply ·2 Ohm Stereo Stable ·Built-In Variable Subwoofer Crossover ·High Level Low Impedance MOLEX Input ·Connector ·RCA Low Level Inputs ·Speaker Output Terminal Strip ·Signal/Noise Ratio: 90dB ·THD Less Than 0.04% ·Frequency Response: 15-30kHz ·Overload Protection ·Thermal Protection ·Short Circuit Protection ·Power On LED Indicator ·LED Diagnostic Condition Indicator ·Automotive Type Fuse Protection ·Dimensions: 14.17'' L 10.03'' W 1.96''
WOW!
zack_vanderpool
zack_vanderpool
columbus, oh
nVRuckus
