PVC vs. AERO PORTS............
From what I've read, aero ports should be 1" longer due to the tapered design...correct me if I'm wrong.
When I calculate port length using aero's, I dont count the flares in the length, and my tuning has always come out to be DEAD on, maybe off by 1 Hz...but nothing more.
So there would be no "major" difference it I had a box that was 3cf ported to 34hz useing PVC, aero ports, or slot ports?? Is is not worth sending the money to get aeros?? I've always used PVC, and i've only used a sloted box once. I gained 1db by swapping boxes. I heard alot of people rave about aeros, so I just wanted to get your (caraudio) opinions. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
P.S. mazdakid your avitar is hipnotizing (sp?).
im no pro, but i really dont think you would be able to hear a huge difference, it would probably show on the mic, but not very noticable to the ear if everything is the same
ok let say you have installed 2 4" regular unflared ports on an enclosure and youre getting slight port noise between 30Hz and 50Hz, replacing them with aero ports or routing the port with a 1/2" round over bit may help with the port noise.
if you have the right port area you wont get port noise. flared ports and rounding over a port is a bandaid, because of failure to calculate port area correctly.
"thats just for the port noise issues"
a 6" is 28sq" of portjust get a 5 gallon bucket or try some 12"
LOL, well the next box i'm working on doing will be done with 4 4" ports tuned to 34hz. I'm thinking that should do the job. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
oxsign
No Affiliation
oxsign
Orlando, FL
mazdakid
