IDSkoT
Resonating Reticular
Not this.run the power of the fans to the remote the ground to the ground on the amp..
The remote isn't supposed to be pulling that many amps.
use a relay in conjunction with ur amp turnon. then run all the amp turn on and fans off of the relay
this will make it so the fans only kick on when the car is on
you need a relay or else it will fry the amp turnon i think due to too much power being pulled, especially if you are running more than one amp
This.
Even though 4 fans are usually equal up to 1 amp, it's still too much for the remote.
