purchasing amp question
First off, I am completely new to car stereo and audio. I read a couple guides on help 101 but just felt in over my head. I recently came across a free 12 inch sub box and free 12 inch kicker comp 8 ohm woofer at my work when a couple purchasing deals went sour and could not be returned. Anyways that leads me here. Had no idea how involved audio can be. I'm not looking for the best amp but just one that will work with my sub. What kind of amp should I be looking for? 1000 watt? 2 way? Mono? If it sounds like I am lost... you're right. I'm trying to slowly get into the car audio world and this looks to be the best place to start.
Any amp recommendations?
Thanks
It's a Kicker Comp so it's around 150 rms. You're going to want to get an amp that does double that at 4 ohm as car audio amps don't have 8 ohm ratings. My suggestion would be to get a cheap 2 channel amp and run it bridged to the sub. Something that does around 300 watts at 4 or so would be fine. That way when you upgrade which you'll eventually do you'll already have an amp for door speakers. You don't need to spend more than 80-100 bucks on it.
First off, I am completely new to car stereo and audio. I read a couple guides on help 101 but just felt in over my head. I recently came across a free 12 inch sub box and free 12 inch kicker comp 8 ohm woofer at my work when a couple purchasing deals went sour and could not be returned. Anyways that leads me here. Had no idea how involved audio can be. I'm not looking for the best amp but just one that will work with my sub. What kind of amp should I be looking for? 1000 watt? 2 way? Mono? If it sounds like I am lost... you're right. I'm trying to slowly get into the car audio world and this looks to be the best place to start.Any amp recommendations?
Thanks
i have an old apline vpower amp still works i used it with 2 kicker comps and it sounded pretty good for a low end system setup
MRP-M350 - Alpine V-Power Series Class-D Mono Amplifier - Black Finish at Abt
mojoe87
mojoe87
birmingham alabama
inferno1985
