Pulsing Power wire.. Holy Cow!
How you broke?
Why because i dont wanna spend money on audio?
Just because i own machines doesnt mean im rich, not many clients are buying from small business owners when it comes to pipping because of wholesale pricing other larger companies can offer. Also i dont have storage for large orders.
Sent from my SM-N910P using Tapatalk
Specialty parts
Ac does it just like D.C.https://m.youtube.com/watch?v=VJn1-bpYi0Y
You need a fast extreme change in current
Like an amp drawing several hundred amps
Ive personally levitated a 300lb steel cylinder with a single turn of copper tubing around it using an ac inverter
If current is flowing you better believe there is a magnetic field
Thats reactance. If the wire is in open air there is no attraction/ opposition
The wire in the middle clearly repels the two wires around it.
It had a huge surge in current causing a emf pulse
The reactance does have to do with it as EVERYTHING has both capacitance and inductance
The amount of inductance on a power line is staggering so it is difficult for it to have a massive current spike capable of causing an emf pulse quick enough to see the line jump.
And yeah if the wire were in space with nothing around it the field couldn't react to anything around it so it wouldn't move but there will always be stuff around wire to have the field react with it may just need to be a larger field to reach far enough
What do you make ? Dont know what it does but it looks very expensive lol !
On the puma I make steel pipes with different specs and threads for oil companies mainly, but it can do several things... Even distribution blocks.. lol
The Engel I make fans and different size rings for ac systems and hard hats and cases for several products from certain companies.
Sent from my Moto G (4) using Tapatalk
Cool ! you could make all kinds of audio stuff probably.
bigblank69
bigblank69
Eureka, MO
ChaseinBass
