ps3 and wii hdtv rca wires ???????
they are both outputs not inputs.....are you wanting to hook up your wii though your ps3?or just be able to hook up one set of cables to two consoles??
as long as you ony have one console on you will be fine
ok I have a set of wires with the 5 componet rca wires on one end and 3 plugs on the other end one for the ps3 one for wii and one for 360
i want to plug the rca end into the tv
the other end I want to plug up the ps3 and the wii at the same time
what I am wondering if this will back feed anything into the other unit
He just want's to have all 3 consoles hooked up at once so he won't have to unplug the PS3 and plug up the Wii. At least that's what I'm assuming. I don't know what would happen if you do it if anything. Best I can tell you is to just try it and see what happens.
nothing "bad" is gonna happen
like I said, out of the wii,ps3 and xbox the cables are all outputs, if a signal tried to get though it wouldnt hurt it
just do it or get a splitter of some type
does your tv have more than one input for component? do you have a reciver??
also the wii can be hooked up via just plain ol rcas, nothing high def about the wii
right this is what i was saying
fatboyracing
fatboyracing
Owensboro KY
Propimp
