properly wire my amp and Sub????
hey everyone i have a question on wiring my Kappa One amp to my JL Audio CS210RG-W3v3-2 subs.
the amp has two sets of outputs but the sub only has one set for two speakers so far i have one set from the amp going into the sub, so does that mean i only have half the power from the amp going into the 2 subs, should i bridge my amp i dont even know if my amp is bridgeable this is my first amp and sub so any feedback and advice will be greatly appreciated Thanks, also im looking for sound quality more than huge bass if that helps.
the amplifier you have, has two spots to hook up speakers, but in reality, its only one set of outputs. it has 2 positives and 2 negatives for easy of wiring. its a monoblock, so just put one positive and one negative in any terminal you choose and you'll be fine. and if the subs are in a preloaded enclosure like your model number suggests, the preloaded enclosure has a final impedance of 2 ohms(that is if you have not changed anything around inside the enclosure. so if this is true, your getting all your going to get outta that amp.
Agreed..Those subs are svc 2ohms, and your amp 2ohms stable,Either way you wire to the amp, will be just fine..+to +,and -to -,and your svc2ohm subs should wire to +to +,and -to - just on one of the terminals at the 2ohm mono load.Shouldnt have any issues
delvecchi088
delvecchi088
Rochester, NY
delvecchi088
