Properly powering LED lights interior
JoeK
I want to buy 12V red LEDs for my kick panels in the front. But how do i wire them so they turn on and off automatically? Ones from walmart plug into the cig lighter which turns off in 10 mins. But i dont want to use that. Can i tap into my HU remote wire? I only plan to run 2 maybe 3 of these. 15-strip lights
Probably just tap into any good sized wire that only has power when the ignition is on LED's don't draw very much.
In my car that is not possible. Only fuse that is like that is IGN1 in my rear box which only goes with the engine
I'll probably end up tapping them off of my remote wire. I did wire an LED bar to my old LC2i and that one is a hog compared to these.
I wouldn't draw anything directly from the remote, that's asking for trouble, I think this is basically the relay that I linked to you, it turns on with the remote wire and supplys a solid 2A of current.
PAC TR-4 (tr4) Remote Turn-on Module - Sonic Electronix
You need to know how much current they take. Remote outputs have very limited current capability, usually less than 200 ma (0.2 amp). If there's no spec on the LEDs you can measure their current with the milliamps function of a DMM. Any more than 150 ma and I would use a relay or that PAC remote thing.
What car do you have that has no wires under the dash that turn on with the car.
I am sure you have 20+ circuits under your dash that come on with the car.
If you are deadset on using your power from your radio just hook it to the red wire going to your radio, it is one of many wires that get power when the car is on.
Do not hook up anything to your remote wire, that is not smart.
I just wanted automatic switched power and i am no good at touching stock wires and making relays. Ill check with a DMM if the red wire is switched and etc, cause that will be easy to run the wires in that case.
I have that PAC module wishlisted if it comes down that i need it.
JoeK
JoeK
Ringtown, PA
>>SQL<<
