~Project Stealth Avalanche~ 4 15's, 4krms, dash mod, *pics*
So i swapped the battery, but the whine didnt go away. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif, i guess the loose terminal maybe caused pico fuse issues, so i gotta ground the RCA's out now (hopefully that will fix it).
I snapped a few random pics, ill post em up later.
Have you swapped rca's to see if its the wire? That and bad rca ouput on headunit have almost always been my problems.
Any new updates?
Any new updates?
not other than swapping the battery.
The RCA's should all be good, unless one decided to just go bad.
I need to swap the ipod adaptor cable out for apples version cable anyways. When i buy that cable, i'll ground the RCA's and go from there.
I did just take another vid while doing vids for another thread. I'll post it up.
how many runs of 1/0 from the front to the back did you do. Also whats the voltage drop at idle.
With that song I never turn full tilt worried its too much bass and gonna blow something haha. Was that at full tilt.
If thats only 4krms then i might only want that much and not anymore that looks very loud like the seats shaking
Two runs (1 pos, 1 neg) between each battery.
Voltage stays above 13 at idle.
Sort of at full tilt. The gains are set at 4000RMS flat, that was two volume clicks down from what the amp is tuned to.
And yes, its pretty loud. That song will move a t-shirt over a foot away from the window. And when i say move a t-shirt, i mean someone wearing the tshirt
so you only got a pos and neg run from the front battery to the back battery. Wow thats crazy. i was thinking i would need a 250amp alt, 4 batteries in the back one upfront and 4 runs of 1/0 meaning 4 pos and 4 neg to the back for around 6k watts.
I deff want to do a build like you did
why would u run a negative run to the back batteries?? just drill a hole and bolt directly to the frame.. i've always run my extra batteries this way
just depends which will give me better voltage some cars doing it that way result in poor grounds and bad voltage drops. I gained voltage by running a ground to the front on my current setup
Supergumby5000
Project: F350 begins...
Supergumby5000
Pullman, WA
WOT
