Project PANDBASSA
You could always just lower the front, cheap alternative,you might actually like the feel/ahdnling
I lowerred my qx4 2" in the front to compensate for sag on a 300lbs worth of install
I have there around 850 lbs extra weight //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
So lowering springs will lift the back a bit UP as well as original springs are too soft if u get me here //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have there around 850 lbs extra weight //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifSo lowering springs will lift the back a bit UP as well as original springs are too soft if u get me here //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I had my springs custom made at Springworks in California. They did an awesome job, and was very reasonable. They were completely custom, as there was no aftermarket alternative with my car:)
Preparing subs, using 4gauge cable for each coil and short pieces of 8 gauge
Many people using 8gauge cable as powercable lol
Took you 3 hours to mount them you mean? Are you serious? Reason? Looks like you used a 5" screw for the mounting bolts lol
You know you wanna find some 3/4 moulding and trim that port... itll be like 8-10 bucks
RookieMekanik
RookieMekanik
ireland
RookieMekanik
