Project Beater
1) Mixing different subs = fail
2) Mixing different sizes of subs = fail
3) Replacing mismatched subs with other mismatched subs = fail.
I don't care how temporary the setup is if you're just gonna do it wrong again.
No you fail, two different size of subs in the same box....//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif WHY ??
they alhave their own air spaces and they are all ran seperatly. two different size subs means more sound the 8s hit faster then the 12 so when i listen to metal there is no lag.
Dont worry, no one is going to steal your jank *** system
i wish some one would i anit worried about shit. go **** yourself i aint like all you other mother****ers who has all this money to blow on expensive subs. i work for below minimum wage and work my *** off for this shit quit hatin and get a life.
1) Mixing different subs = fail2) Mixing different sizes of subs = fail
how does mixin different size subs fail. you are a complete idiot a smaller sub responds faster thean a bigger one therfore you can still hear it when the twelves lag. go **** your self with your mb quarts
where do you get a job below min wage....unless ur a tip worker like a bus boy or waiter and even then you end up makin at least min wage in the end and alot of times way more than min wage.
Subs don't lag you big dick. The only difference between an 8" of certain sub and a 18" of a certain sub is usually the very little added weight of the extra cone (and basket size, etc, but those aren't moving parts..), and that's not enough to make any lag.
your wrong here any size sub can hit as fast as any other size sub so you still fail with you lack a knowledge
kottonmouthking
kottonmouthking
Kansas
Johnny Law.Lulz
