profile california amp 640sx
  • 1
cameronp
27
cols oh
hey guys im thinking of getting this to run my highs in my car, what do you guys think of this amplifier?? good and bad feedback welcome
a.. 2-, 3-, or 4-channel output
b.. Tri-Way capable
c.. 75 watts x 4 into 4 ohms
d.. 110 watts x 4 into 2 ohms
e.. 225 watts x 2 in bridged (2-channel) mode
f.. requires 4-gauge power and ground leads - wiring and hardware not
included with amplifier
g.. continuously-variable high-pass and low-pass crossovers (40-130 Hz at
12 dB per octave)
h.. 2-ohm stable in stereo
i.. gold-plated high-current cable inputs for maximum current transfer
j.. continuously-variable (0-12 dB) bass boost at 45 Hz
k.. 105 dB signal-to-noise ratio
l.. two 30-amp fuses
m.. 13-3/4"W x 2-3/8"H x 9-13/16"D
I quick call to each shop should help you weed out the outdated ones. Good luck. Do come back with updates and pictures if you please.
909
195
  • Locked
439
Amp
389
cameronp
cameronp
cols oh
cameronp
    May 22, 2024
    May 22, 2024
