problems
just put my subs in and......nothingi got power to my amp, the light turns on and all but no bump
im thinkin rca's, may be a dumb Q but which should they be connected to on the HU?
If your HU has a dedicated subwoofer output then it needs to be connected to those.
If your HU has a switchable set of preamp outputs that can be swapped between rear and sub out use those and make certain that they are set to subwoofer mode.
If you have neither option above but two sets of preouts use the rear output.
Got a cd walkman or something similar? Get an adapter for it so you can plug the RCA's straight into it from your amp....this would be a good troubleshooting tool for you to have anyways.
bannock
bannock
winnipeg,mb
snoopdan
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
